HAL.Sys.CardInVoltHigh
Description
The card microcontroller has detected that the input voltage to the card is too high. To prevent damages to the card, it has been shut down.
Remedy
Power cycle the chassis or wait around 30 minutes to see whether it will come back to normal operating range or not
Severity
Critical
Message Text
Input voltage for %slot% in channel %channel% is higher than normal operating range. The card will be shut down
Message Parameters
Name Type
slot String
channel uInt
Applicable Platforms
